From a PM on the subject. Take it for what its worth…
"I've messed with 100% water, 100% methanol, and every combination in between. The best all around results have been with -20F washer fluid. It has around 35% methanol and is under $2.00 a gallon. So I just go with it. My manifold volume has been increased from 2 to 5 liters so I have the space to locate a big injector right under the blower outlet. Allows me to inject 2x 325ml W/M both before the blower (as guys typically already do) and I can spray 1x800ml into the hot compressed stream after the blower. I really need to get one of those air temp gauges the Mustang guys use to measure their blower outlet temps. Cheap ones are under $100. Expensive ones around $280. One thing I like about W/M vs just having an intercooler is the benefit you get from the water vapor. Controls combustion temps, inhibits detonation, flash steams keeping valves/chamber clean, as well as increasing cylinder pressure during combustion since steam expands 800 times its volume. So at the end of the day one has to evaluate simply having a cooler/denser air charge (intercooler) or having the benefit of a cooler air charge and high humidity (W/M injection). THe best option would be to do both IMO. Spray prior to the blower to get a good cool air charge into the blower and help keep the blower cool, and then a good intercooler to further get the charge cold. Once thing too, spraying before the blower helps seal the blower rotors and well as keeping them cool. Folks always get concerned about spraying before the blower…aka Isn't it bad for the rotors? In actuality, its just cool humid air being compressed. Its not a spray hitting the rotors since everything flash evaporates. Probably not much different than driving on a hot summer day in a down pour when the air is fully saturated."
I just got back from a 2 hr drive and was into boost pretty good. I only used 1.5 gal of fluid and 1/2 tank of gas. So with a 2.5 gal reservoir, I have yet to actually "run out"
