RT-10 hardtop head room vs GTs, Also RT-10 Guys, do u put top up when away from Car.
Jeff Torrey
Plaistow, NH USA
With an RT10- If your car is out of your sight for any amount of time. You either put the Hartop on when you go out, or stow the soft top and install at your destination. Install takes about 5 minutes. Headroom in an RT10 with the soft top is tight. I am 6'1" and my head can hit the rail over bumps. You can lower the seat 1 or 2 inches. On the 2 " lowering kit, the seat no longer moves forward or back. The hardtop gives you plenty of headroom. You can not stow the hardtop in the trunk. But you probably know that.
With a GTS- Head room is not an issue. Good and plenty.
ViperGear
