RT10 Idle Speed
bennno
Does anybody know the idle speed for a 94RT10 and if it is adjustable?
Mine seems to idle at 3-400RPM at which speed it sounds fine, but the alternator isnt doing much in the way of charging the battery?
Can anybody help, I am in the UK without a manual?
Bennno
Scorch
Shelby Township, MI
My 1994 Service Manual says 704 rpm, +/-25. I don't believe the idle speed is adjustable (computer controlled).
In dash tach's are difficult read that accurately. If you really want to know your idle speed I'd suggest getting a hand held unit.
Hope this helps.
Scorch
Shelby Township, MI
My 1994 Service Manual says 704 rpm, +/-25. Those numbers are with the engine fully warmed up (running at least 15 minutes). I don't believe the idle speed is adjustable (computer controlled).
Hope this helps.
B
bennno
Thanks for that its only just under 500 looking again so I guess that explains it.
Checking the volt metre it looks like the alternator doesnt get much power at 5-700rpm though...it needs 8-1000 to start the gauge moving up above 12?
Is this normal?
Bennno
