leaking above windshield. used dielectric grease so far. ive decided to place weather stripping along top, is there any specific type and thickness i should use
Have you tried tightening the top? Take a 1/4'' drive rachet with a 10mm socket and remove the hold-down clamp. You should be able to move the c-clip one notch to tighten the top. It worked for me.
Neat idea. My '94 needed a 13mm socket, and you really don't have to remove the nut; loosen it, remove c-clip and re-install, then retighten. I never knew....
