Rust protection module..Does anyone have them?
gen2lover
Windsor,Ontario
When I bought my 2000 rt I had a local dealer install this under my hood.I cannot think of the name of the company off the top of my head.He said it would prevent any new rust and all rust from forming on the car the moment the modeule was put on.I have had my car only since May 2007.Can anyone tell me if they do actually work?:dunno:
G
gen2lover
Windsor,Ontario
How Rust Protection Works
Rust is the result of the corrosion of iron and steel. Iron is produced from iron ore. Iron is created by heating iron ore, and steel is produced by combining iron ore, carbon and other selected metal alloys. Iron has a tendency to return to its natural form of iron oxide or rust.
To understand how rust is created, consider the chemical reaction in a battery:
A carbon rod (called the cathode) is surrounded by a zinc case called the anode. When a wire is connected to the outside of the battery through the two terminals, current flows between two metals through an electrolyte (electricity conducting paste). Not only does current flow from the zinc case to the carbon pole, but particles of zinc are eaten away (corroded) and deposited on the carbon pole, through molecular movement. A similar occurrence happens on your car's metal surfaces. Miniature "batteries" are formed all over by:
  • Two different metals near or touching one another (Eg. seam welds).
  • Impurities within the metal causing localized areas of differing electrical potentials all over its surface.
Different concentrations of oxygen in metal, causing localized areas of differing electrical potentials across the surface. In order for these "batteries" to operate they must have an electrolyte. Water is a suitable electrolyte - even humid air will work. If the moisture contains acids (usually from air pollution or salt from the ocean or road) the electrolyte conducts electricity very efficiently, speeding the corrosion process. An automobile is exposed to these conditions through:
  • Humid or Salt Laden Air.
  • Rain and snow.
  • Condensation.
  • Pockets of dirt that hold moisture from the rain or snow.
Rust-Gard uses a microprocessor controlled circuit to generate a negative electrical charge to your car's grounded body panels which in turn inhibits the forming of rust. Unlike conventional rust-proofing that is sprayed onto the underbody of your car, Rust-Gard protects all continuous metal panels throughout the car. Rust-Gard is particularly effective in reducing rust and corrosion formed when the underbody of your car receives nicks and cuts to the vehicle manufacturers own body sealant, during the course of its normal life.
Cars today has approximately 3,000 welds. Welds and their immediate vicinity are the areas most vulnerable - and are the areas hardest to protect with conventional rust-proofing treatments. Rust-Gard is the only practical method to protect all the continuous metal throughout your car, including the inner cavities.
Through innovative design, Rust-Gard works especially well in humid and harsh environments - the times when your automobile will need it most. Rust-Gard has been manufactured to reduce rust and corrosion from both the outside and inside of your car.
Electronic Rust Proofing / Rust Protection is better than chemical Rust Proofing
G
gen2lover
Windsor,Ontario
looks like an alarm or bomb. always 2 lights beeping on a small black box...with wires going out of one box to a second box.
My car is in my garage....put away for the Winter.I have to hook up my digital cam and get some pics of my car and post a few. All my car pics are on my camera phone.
Tom F&L GoR
Wappingers Falls
Those marine radiator caps are similar in concept. They purport to protect your system by having a huge sacrifical anode, i.e. something that they want to corrode. If it corrodes, then your cooling system parts don't. The weakness in that argument is that the coolant is trying to stop corrosion and when you introduce something designed to corrode, all your anti-corrosion performance is used up that much quicker. This is OK in a boat engine that uses sea water and not a coolant charge.
If the microprocessor is essentially running current in opposite the normal direction to prevent rust, there is still a "battery" action going on somewhere. Parts don't rust at the same rate, so it seems like even it if worked on one spot, it would cause rust in another.
Vipers don't have continuous metal panels throughout the car either.
DrDJ
Chesapeake, Virginia
Works for boats in brackish or salt water, so unless you plan submerging your car, your dealer ripped you off.
DrDJ
Got_Vnum
Northridge, CA
  • Rain and snow.
  • Condensation.
chimazo
Clarksburg, MD
I bought one right after I installed my "Turbonator," electric turbocharger, and magic fuel catalyst that lets me get 40mpg.
It's THAT good!:rolleyes:
ViperTony
"I installed your product (RustStop®) on my truck five years ago. I just sold that truck a few months ago. In the five years that I owned the truck, the only rust that got significantly worse was on the tailgate and the front bumper -- places that I knew were electrically insulated from the rest of the truck...... Thanks for a great product!"
So, the rest of truck rusted less significantly. :D I love this country. :2tu:
Schulmann
Canada
The only way to slow down rust or prevent it, is to oil the frame/body of you car with a special oil. Nothing else works. Anything else is pure hallucination depending on what you smoke ...
I had a 1985 Mercury that I drove down to Mountain View, CA. When I bough the car, it was severely rusted but oil prevented further domage. I exchanged it for a Dodge Stealth in 2000. When the dealer opened the hood, there was so much oil everywhere he thought that I blow up the engin.
sham5430
