milehigh SRT-10
About 16 years ago I purchased a silver '98 GTS Coupe, but was only able to hang on to it for a year. Times have changed, and yesterday my silver '04 arrived with 8,000 miles. Needless to say I am fired up. Noticed after my first drive last night a small oil leak on the garage floor between the oil pan and the inside of the L/F tire - the oil cooler lines I suspect, as it appears to be engine oil. I noticed in the forum that crank dampner bolt should also be checked. That will be next. The car has new Michelin Pilots and is all stock. Thinking about the Corsa or Mopar Cat-back and leaving it alone otherwise. I have a rotational clicking at slow speeds that is coming from the R/R wheel that goes away as I pull on the e/brake. I suspect it's a dragging e/brake shoe that needs adjusting. I will be looking at changing the fluids, as the only record I have is for an oil change at 4000 miles. Any other recommendations or suggestions for a new Gen III owner? Anyone know who the Viper Tech(s) in Denver are anymore? Thanks in advance. Take care.
