Mopar Steve
Shifter is very stiff and difficult to move after it sits for a while. After the car warms up and I have driven it a short distance, it loostens up a bit but is still tight. Is the problem in the shifter or the trans?
Sounds like our 03 with stock fluid...worse in cool weather.
Did you inspect your lower shift boot? It could be torn and getting caught in a weird orientation. As the rubber warms up it gets more pliable.
Motor mounts can make the shifter stick. Do you feel more vibration than usual?
Neither of these explains the improvements after the warmup.I had this happen when I installed my shift knob. I didn't realize the lower boot had gotten bunched up in a weird way. It would feel like I was getting some resistance at random times. It's worth looking at - 5 minute inspect/fix.
... Fluid is fresh maybe one year or 1200 miles. (all my flids are always fresh)
These don't match the issue.
Maybe I can describe it better. engine running or not, with the shifter in a neutral position, wigling back and forth it feels like it pulling through extra thick peanut butter. When it gets warm, it moves exactly as it should. There is NO problem getting it in gear or shifting between gears just very "thick" feeling.
Take these observations however you wish:
It has been my experience that stock Vipers with factory fill Mopar Dexon II-e (1992-1995), Dexton III (1996-1998), and ATF+4 (2008-2010) are consistantly easier to shift when cold that stock Vipers with factory fill Mopar Synthetic Manual Transmission Lubricant 75W/85 (OEM fill starting in 1999 and used through 2006 model years). As many already know, the TSB covering Neutral Gear Rattle (NGR) issued in 1998 allowed replacement of the Dexron with Mopar Synthetic Manual Transmission Lubricant 75W/85 (1994-1998...skipping 1992 and 1993) which helped to diminish the NGR.
Without taking measurements to actually measure the different forces needed to move the gear selector in the same car, I can affirm that indeed the Mopar Synthetic Manual Transmission Lubricant 75W/85 feels "stiffer" when "cold". This is not new info...as it has been discussed here for many years.
But, just for the sake of argument, I did a non-blinded, non-scientific, subjective assessment of these fluids today in 6 Vipers...all of which have been "static" for at least one month and all engines "off" for at least one month:.
1996 R/T 10...transmission housing 59 degrees Fahrenheit...Mopar Dexron III ...easy to shift (YES...moving to ATF+4 on next fluid change).
1997 GTS......transmission housing 59 degrees Fahrenheit...Mopar Dexron III ...easy to shift (YES...moving to ATF+4 on next fluid change).
2001 GTS.....transmission housing 59 degrees Fahrenheit...Mopar Synthetic Manual Transmission Lubricant 75W/85...more resistance to shifting.
1999 ACR......transmission housing 53 degrees Fahrenheit...Mopar Synthetic Manual Transmission Lubricant 75W/85...more resistance to shifting.
2008 SRT Coupe...transmission housing 55 degrees Fahrenheit (it sits above to 2010 ACR)...Mopar ATF+4...easy to shift.
2010 ACR vert "soft-core"transmission housing 53 degrees Fahrenheit...Mopar ATF+4...easy to shift.
Probably, more significantly, when driving these Vipers on the same day(such as two months ago), the differences stated above were quite obvious.
Bottom line...I'm not too worried about Mopar Steve's Viper unless more pathology is described in a subsequent post.
Since many of us are stuck talking about Vipers instead of driving them due to the weather, we need some entertainment...so let the flack fly !!![]()
Did you drop some ****** in there?![]()
Steve, one thing that is problematic with my post is that you and I may have a different opinion as to "stiff".
If this is a new problem for your Viper but only noticed in say 25-35 degree weather, I'd say sit it out and see what happens as Spring approaches.
Tom Sessions may have some more meaningful facts for you as I happened to get a call from him as I was posting.
Good luck !!
Steve,
At your advanced age, I'm not sure you are qualified to give either a subjective, or for that matter, an objective opinion as to what "stiff", is!![]()
He has plenty of us near by! Trust me, Steve has forgotten more about these cars than most of us will know, so when he says somthing is "off", it's "off"!!
Viper owners meeting up to discuss stiffness matters, hmmm...Do you have any fellow Viper owners nearby, maybe you can arrange a side by side test to see if there is a major difference.
Viper owners meeting up to discuss stiffness matters, hmmm...![]()
