Short Shifter Rods New Custom fit 92-08 Vipers
Dave's Big Brakes
San Diego Ca USA
These new custom fit s/s rods with billet collar rings to seal off the heat at the lower shifter boot. Comes with a new jam nut, zip tie, and allen wrench for collar install.
Picture show want the difference in heights using OEM or aftermarket handles.
The above picture shows the 1" & 2" lower rods using the OEM shifter handles.
The above pictures shows the aftermarket knob adapter using the OEM isolator
The above picture show the new heat collar on the lower shifter boot.
DVS-032 $59.95 your choice of 3 different kits.
Dave's Big Brakes
858-382-4713 cell
D
Dave's Big Brakes
San Diego Ca USA
Here's a few more pictures & options:omg:
Above picture shows all 3 versions OEM
The above show a option of a 8 Ball (most colors available)
The above shows the end view with 8 Ball mounted.
Dave's Big Brakes
858-382-4713 cell
GBS
South Florida
I have been thinking about going to a shorter shifter. Is it as easy to replace as it looks? I have an 02 ACR.
GBS
South Florida
I'm pretty good with tools. Can you tell me if I would need any special tools and what's involved?
Thanks!
Paul Hawker
San Diego, Calif, USA
Drove an 08 last week (Thanks Dave Andrews) that had a short shifter installed. Best feeling and most accurate of any Viper I've ever driven. (Don't know whos' shifter was installed)
eucharistos
Houston
How hard/easy is it to unscrew the factory ball handle ('02)? Will it get damaged?
eucharistos
Houston
See pictures above, the lower part of the OEM handle has a flat spot to use a wrench and right below it is the jam nut. Loosen jam nut and unscrew the OEM handle
Doooh - make sense now....OEM handle = ball & shaft....very nice kits!!
Thanks for the clarification
D
Dave's Big Brakes
San Diego Ca USA
Two new combo's
New 6 speed pattern on a 8 ball with aftermarket adapter
Side shot of different combo's
Big Brake Dave :drive:
Dave's Big Brakes
858-382-4713 cell
SilveRT8
Boucherville, Quebec, Canada
Hi Dave
Do you make the 8 Ball with 6 speed pattern in White also ?
That would be my dream shifter, memories of the old Hurst shifter with big white ball.
Claude
