Something you should be aware of if you scrape the facia against a curb..
Ulysses
San Diego, CA. USA
Last week was my first time on a road course as some of you may recall (and what a blast it was!!). I unfortunately wound up on the dirt and drove over a small ditch bumping and scraping my front facia on the passenger side (no biggie).
When I got into the pits, someone had mentioned that I was leaking coolant. I figured I was just dumping through the overflow because if the heat of the day combined with the fast driving, but the car was not over heating at all, so I didn't give it a second thought. Driving home through the desert, I kept an eye on the temp gauge and all seemed fine.
Well, I had some time today to work on the car and was planning on burping the coolant system. I noticed the facia bottle was extremely low so I started filling it with a coolant mix when I noticed coolant dribbling all over the garage floor. "Hmmmm, that's odd". I reached in to see if the overflow hose had fallen off the metal tube it was attached to or if it came loose from the overflow bottle. Nope, and it was dry on top. I reached down below and the bottom of the bottle was soaking wet. It had to be a hole. So, I ended up taking off the facia to get a better look and sure enough, there was a hole on the bottom of one of the corners of the bottle!!! How the heck did that get there!?! After close inspection it was obvious what had happened.
The bolts that hold the facia onto the radiator panel below are very long and the facia bottle sits very low. One of those bolts sits real close to the corner where the leak was. You can see the mounting hole for the bolt in the picture. When the car had made contact with the ditch, it bent the lower panel up sending the bolt into the facia bottle. The bolt did not have to travel very far upwards either to make contact.
So, for those that have hit a curb up there or those that might, be aware that you can easily puncture your facia bottle, doesn't even have to hit very hard. Thank God I didn't end up over heating in the middle of the desert somewhere on my way home.
JonB, I'll be callin' ya. I need a part
Qualitywires.com
Louisville, KY
Hey, thanks for writing that. That is informative and the pics really helped out to see what you were talking about.
BigsViper
West Texas, USA
Ulysses, I'm wondering about pre-emptively replacing that bolt with a shorter one, or cutting off the long bolt to eliminate puncture possibilities. From your experience is this possible/advisable? also would I have to remove the facia to access this bolt (I'm not at home where I can crawl under there right now) Thanks and great heads-up!
U
Ulysses
San Diego, CA. USA
Thanks all,
It was a bummer having the facia all scraped up there but, at least I didn't end up in a wall or something. It could have been worse.
Ron, I sent you email.
Don, The bolt is accessible from underneath. I'll take a look at which bolt it is (1s't or second). It is very possible to put a shorter bolt there. I'm heading out to the hardware store tonight. Looks metric though, so I'll probably end up going to a nuts and bolts house.
NCVCA
Raleigh, NC USA
Evidently this is a somewhat known problem. When I took delivery of my 2000 it was "missing" a bolt for the facia. I called Bill Pemberton at Woodhouse and found that it was removed intentionally - for this very reason. There haven't been any ill effects of having that one bolt removed.
I've heard of others removing it for the same reason...
Jeff
Vip-RT10
Clearwater,FL.USA
Thanks for the info, but sorry about the accident. This will help us to better assess the situation on a similar situation.
U
Ulysses
San Diego, CA. USA
There is a small removable panel down there that is held on by two bolts, this one being one of them. It is the second bolt from the outside.
Removing it completely might leave it flapping in the wind. I'm looking for a smaller bolt. Shouldn't be hard to get.
ViperGear
