SRT "Bolt On" Breather System Modification
Cape Coral, FL
We now have available a "bolt on" non-permanent breather system option for the Gen-4 and 5 cars. Rather than drill and modify your valve covers for a leaky and loosening prone AN Bulkhead Fitting that was never designed to fit, we have a new and proven solution that makes this modification much easier.
Option 1 is a single port fitting and adapter with a JIC end for use with any JIC hose ends. Simply cap your Driver cover and manifold port, route the passenger to a catch can, and you're done.
Option 2 is a dual port. We will remove your driver side fitting and fit with a JIC end. Cap your manifold, and route both ends to a catch can, and you're done.
Pricing is $75 for the adapter, plus whatever hose ends you may want. Driver cover mod is also $75, plus whatever hose ends you may want. We can weld up the other versions and powdercoat covers for those looking to change over.
Pictures:
