Steering Column Cover Removal
Shelby3
liu;g
How does one remove the steering column cover on a 96 GTS? I've got one screw removed from center on the bottom. There are two additional holes at each side on the bottom and I can't see inside to figure out what's in each. Anyone? Thanks
Nadine UK GTS
Bath, Somerset, UK
If I remember correctly its a very small torex bit, T-handel type bit, not socket fit, each side. If you need me to let you know the exact bit size let me know, I'll go see?
Nadine UK GTS
Bath, Somerset, UK
OK, I went to see, it's the same torx as the center screw, but deep, the size is T-20, Snap-on do a 5 piece T-key set which has this bit in it for the job.
wizzlepoof
