Stoptechs, what do they cost and what is the diff in performance?
Mark Red GTS Cooper
Gainesville, VA, USA
Dan,
I just put a 4 wheel set on my Viper and they are day and night from the stock brakes. I have found that they do not lock up like the stock brakes, and cool down a lot faster.
The width of the rotors compared to stock is quite a bit more, and the rear calipers are four piston but proportioned for the balance.
As far a drag racing, the stock are fine, they never heat up enough to fade, but the stock on a road course could be trouble once they get hot.
Give me a shout , also if you have not bought them by VOI, I will take you for a ride, or you can drive to see how they feel..WELL WORTH THE MONEY!
Mark
SSSSE YA
Simi Valley, CA, USA
Hi Dan,
Before you but anything please check the Wilwood big brake kit. Its a 6 piston caliper, ss lines, light weight hat with rotor for around 1,500 to 1,700 dollors email [email protected] for more info.
Robert Bucholtz so cal Viper Club
GaryA
USA
I have the Stoptech big brake kit and am very happy with it. There's no need for a proportioning valve since the system is balanced at the factory.
I originally had the Wilwood setup on the front wheels and was relatively happy with it except I wanted a matching set for the rears. Nobody made a rear setup that worked without some serious cutting. With the Wilwoods on the front and the stocks on the rear, I found that I locked up the rear wheels more easily.
The Stoptechs are definitely the way to go.
FirecatF7
