SUNBURN - Yes! Sorry my GTS bros. Days like this made for RT/10!
ROCKET62
Has Left the Room!
Phoenix, AZ bye-bye IOWA
Gotta love having to "Go to work" 90 miles away and driving the RT-10! Warm weather - 83 degrees - almost hot - hit Iowa today and HAD to take the top off, take the windows out, and hit the back roads of Western Illinois / Eastern Iowa.
Absolutely a perfect day! Days like this were made for RT-10! See my Avatar for a slight change in weather from today. :headbang:
Mike_W
Sunburns are bad for you.
Thermal Erythma occurs when your skin has been overexposed to too much UVB. UVB is a shorter, more compact and squiggled light ray than UVA and when it hits the skin, it releases energy.
As the skin becomes damaged (cells die), blood comes to the surface of the skin so that white blood cells can begin the healing. This is why your skin turns really red, and since nerve endings have been burned, this is why it hurts. The dead cells pose no problem, they are dead and thats it. The damaged cells however pose a problem, as they may mutate while healing, and then you have a form of skin cancer.
So you shouldn't drive a RT/10, drive a GTS. That's the moral of the story.
Mike
FE 065
MI
Sunburns are bad for you.Thermal Erythma occurs when your skin has been overexposed to too much UVB. UVB is a shorter, more compact and squiggled light ray than UVA and when it hits the skin, it releases energy. As the skin becomes damaged (cells die), blood comes to the surface of the skin so that white blood cells can begin the healing. This is why your skin turns really red, and since nerve endings have been burned, this is why it hurts. The dead cells pose no problem, they are dead and thats it. The damaged cells however pose a problem, as they may mutate while healing, and then you have a form of skin cancer.So you shouldn't drive a RT/10, drive a GTS. That's the moral of the story.Mike
OUCH
Yellow Fever
San Diego , CA
Mike
Owning a GTS in Southern Kalifornia should be a Crime :D
YouWish
U.S.A.
Mike
No...owning a RT/10 should be a crime. :eek: Just playin' with you!!! :D
2001 Sapphire Blue
KC VCA MEMBER
My forehead is burned as we speak!! Took the afternoon off and put about 150 miles on 'er. Ahhhhh...fresh air, sunburn, and a Viper drive...nothing better!! :headbang:
