KaiPL
Well, I installed my Team Tech six point harnesses yesterday.
These are really nice harnesses. I got them from the always helpful Jon B at Parts Rack (Thanks Jon!)
I got to select my own colors, went with black with red pull tabs.
The harnesses come with a video which shows how to do the installation.
Finding the pre-placed holes was a real chore, even with the video. For the outboard holes, I found it easier to just peel back the carpet and insulation, rather than keep probing around with an awl, trying to figure out where the hole was. I think my insulation was thicker than that in the instructional video as well. The outboard holes were covered with two layers of insulation, well over 1 inch thick in total.
The first one took me over two hours, with much cursing and grunting. The second install took only 40 minutes, with the only cursing coming when I dropped one of the bolts between the drivetrain tunnel and the carpet.
Once the belts are bolted in, they are pretty easy to install and un-install. I'm just leaving the waist and crotch straps hooked in, out of sight behind my seat. The shoulder straps clip into eyebolts, so they are relatively easy to attach and remove.
So, to get the harness ready, I just thread the diaper-looking crotch piece into the crotch straps, hook up the shoulder straps clips into the eyebolts; thread the shoulder straps though the seat backs and through the buckles; clip everything in, and I'm good to go. Not a bad system, as when not deployed, you can't even tell it's there, but when you need it, it takes less than 5 minutes per side to get ready to go.
The harnesses seem pretty comfortable. I will get to test their driving comfort next Friday at the track. (hopefully I won't have to test their safety.) It will be interesting to try some serious turning with the harnesses on, and see if being tightly strapped in makes a difference in my driving.
Kai
Kai
