Roffle Waffle
- Joined
- Dec 25, 2009
- Posts
- 266
- Reaction score
- 0
anything I can do about it? Its embarrassing not being able to do a u-turn in an intersection
Rear wheel stearing... LOL!!!!
Its not the best. Try doing it here in the UK on our roads..
Better yet, a Miata.
Here's a video.. once you snap it loose, just be moderate with the pedal, Viper has enuf torque at low rpm to keep it sliding around.. most make the mistake of too much rpm and lose control..
http://www.wincom.net/mnllehti/Roundabout_turning_circle.wmv
THAT'S the way to turn a 360!
~juli
Technically it was 540 degrees.Thanks juli and eucharistos
for a second there I thought I was posting at the Alley.
I'd prefer not to spin the tires every time I have to turn the car around at an intersection though. I guess the "long way 'round" is the simple answer
A wide turing circle is an expected outcome of wide front tires.
You're right about that, rims are like drums / barrels interfering with suspension components, and also there is quite a bit of scrubbing, when in full lock the turning radius path of each tire becomes less concentric, fighting each other to turn on a different radius center.
I made a little CAD video illustrating this..
http://www.wincom.net/mnllehti/2000_Black_RT10_Ackerman_Video.wmv
