HaWiiLuVeR
Hey guys, im new to the board, but not to cars.
ive got a '69 charger (see signiture), that i put a t-56 in. im having some problems with the clutch. ive been thinking i had air in the line, but now the resevior is dry. that has happened twice now, but the first time i didnt think anything of it. i lost all the clutch pedal and had to drive home without any clutch (boy was it fun). i havent had time to get under the car to check for leaks, but im thinking that the seals or something inside the throw-out bearing is bad, allowing fluid to leak past.
Has anyone else faced a similar situation?
and if it is bad, do i need to replace the entire slave assembly, or can i just replace a part of it?
Thanks for the help.
