IF YOU ARE GOING TO REPLACE, A STOCK SET WILL FIT THE BILL, BUT WITH A CAM OTHER THAN FACTORY SPEC, YOU MAY WANT TO GO WITH AN ADJUSTABLE CHAIN AND GEAR SET. THESE ARE AVAILABLE FROM MOPAR PERFORMANCE AND MANY OTHER PURVEYORS. MOST REQUIRE SOME MODIFICATIONS TO THE CAM, I.E. DRILLING ADDITIONAL HOLES FOR RETENTION AND ADJUSTMENT. WITH THE FACTORY GEAR SET, A VEC IS STRONGLY RECOMMENDED TO MODIFY THE FUEL CURVE.
