Hi Guys,
We answer questions all the time about dyno testing and thought we'd share with you our procedure. We do this to produce the most repeatable and best numbers we can. Anything less than this will typically not yield the best results.
When doing a dyno test, you need to do a few things to prepare beyond the normal mechanical check of the car.
1. Check for full throttle. This typically means removing the carpet mat.
2. Check oil level. Do not fill beyond max.
3. Check rear tire pressure and set to 36 psi.
4. On the way to the dyno, punch full throttle a few times, even if it's just momentarily in order for the PCM to see / learn what you're about to do on the dyno. Otherwise, your first pull could show a little low.
5. Put a fan in front of the car and raise the front of the hood up for better airflow.
6. Have the dyno operator set the smoothing to 2 or 3 before the pull, not after.
Hope this helps everyone.
Sean
Sean
