Tire Sidewall "SHREADS" - Need Advice
Janni
Raleigh, NC, USA
Re: Tire Sidewall \"SHREADS\" - Need Advice
My guess:
Your tire went flat - probably due to a foreign object. Then, as the tire deflates, the inner rim hits the inside sidewall first due to the negative camber in the back, the rim slices through the sidewall. Not actually the cause of the failure - more like a result.
Check for a puncture. And let us know.
Geoff Green
Greenwich, CT
Were you really in the left lane doing 65? In CT/NY you would have been run over.
Mike Brunton
N. Andover, MA
RJ,
These tires are so low profile, that it is very hard to tell by driving that you have a flat tire.
The first telltale signs are that something "feels strange" - a little more road noise, car pulls slightly, seems "darty" on the road, ride seems less harsh but only when the deflating tire is the one that hits a bump, etc.
The Viper could use a pressure sensor system - but I can see why they don't want to add something like that.
Lucky you caught it and not the guardrail!
zoomie
Owings Mills, MD, USA
Russ, I had almost the exact same experience, one week
after getting my GTS. My wife and I were driving home at midnight in a light rain, after an all day touring
run with the Va/Md club in the Va Blue Ridge mountains.
On the D.C. Capitol west side beltway, left fifth of six lanes, moderate traffic, I start to hear, and feel,
a low rumble. After the proverbial "oh, sh&t..",
I try to get over to the right shoulder, through traffic. Finally, with tire literally flopping, I stop just barely on the shoulder, then roll slowly another ten feet, hoping to not ruin the rim, to get enough off the shoulder to work on the tire and not get killed. Dark as H&*L, rain, no light, I get
out the spare and jack, my wife reading where the jack point is, finally find the jack point and get the jack under it when a road service truck pulls up. Light ! He wants to put his jack under the side sill - no way ! Get the wheel up and off and the spare on. Try to put the shredded tire/wheel in the trunk ! Finally just set the whole thing in there on edge ( later get it in with friend's help ), and tie the hatch down with a
piece of towel from the road service guy. ( Thanks for the light and tie !) Did not damage the wheel well, or the rim - yes, ecstatic! nothing else !
The original 18" Sports with only 5600 miles on them, 8/32
tread, had two pea sized holes in the sidewall, shredded both sides.
Some A&% dropped a load of something, never saw it. Great driving the rest of the way around the Capitol beltway, up
95 to the Baltimore beltway, around the west side, up 795..
at 50, at one am, with the hatch part way open, in the rain,
and shredded tire hanging out.
Original factory tires, no road hazard warranty, Michelin list is $700 !. Luckily, a club member gets club members wholesale, ( Thanks, Joe !! and Ron and Andy ! ),
AND road hazard for all four at $16 per tire ! ( a week later I find a small screw in the NEW TIRE, and they fix it under the warranty, internal layered patch. YAY! ) and find out the RIGHT front wheel had a frozen lug from someone cross-threading the lug with an airwrench. Could not get it off.
Wouldn't THAT have been fun. or the tire blow up in the mountains at speed on tight curves with the other eleven Va/Md club Vipers right behind !
Check your lugs. Carry a light. Get road hazard insurance ! Check pressures OFTEN. As always, glad that you and rest of car
are fine.
Marv S
Scottsdale, AZ
Going to drive the car a week ago and thought the Rt rear tire looked a bit low. not flat, but low. Took a measurement and it had only 4 psi air in it. Sure enough, there was a bolt in the tread. Stiff sidewall but it would have come apart on the highway if I hadn't noticed it.
Chuck 98 RT/10
tampa, fl USA
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Geoff Green:
<HR></BLOCKQUOTE>
Good catch Geoff, but don't count on it. For the sake of um, legalities, insurance, etc. we have to know that Russ was doing the speed limit and like the rest of us, would never exceed it.
Ron
Indianapolis
<FONT face="Comic Sans MS">Smartire wireless pressure system costs less than 1 new tire and is available from Jon B!
(no, I don't own stock in the company)</FONT f>
ViperGear
