To loud, which muffler should I install?
1TONY1
Dalton Ga. (Chatt. Tn.)
I have a Dynomax superflow, straight through can type (not bullit type) and a Moroso spiral flow muffler in each side sill.....no cats.
J
jp
Umea, Sweden.
That is actually the muffler I had in mind, but do they really fit (6" round) in the side sill?
/JP
Dynomax race mufflers. 6" round - 3" inlet/outlet. They come in 18 an 24" lengths.
Anthony - 98 GTS
Houston, Texas
/JP
Yes - they fit. It is tight with the sill insulation. It helps to have a lift when re-installing the sills.
J
jp
Umea, Sweden.
It is with Belangers, no cats, 3" pipes and Race Bullet mufflers. Had this set-up last year with stock engine...sounded tame, but now with the new engine it's way to loud to be driven on the street. The engine is built for nitrous abuse.
THAT SOUNDS BEAUTIFUL!! Keep it just like that. What setup do you have?
Austin
Clear Lake, TX
Do you have a special cam setup as well, or is just whats listed above?
J
jp
Umea, Sweden.
The camshaft is my own design.
