TOP SPEED IN 4TH GEAR IF I GO WITH 3.55'S?
FastMatt
alamogordo nm USA
TOP SPEED IN 4TH GEAR IF I GO WITH 3.55\'S?
IF i USE 26" TALL TIRES? (mt et STREETS 26x11.5)
I want to be able to still run 135 in the 1/4 mile, will the 3.55's put me on the rev limmiter in 4th?
I am looking for 10.50's@135mph on the NOS...
Marv S
Scottsdale, AZ
Re: TOP SPEED IN 4TH GEAR IF I GO WITH 3.55\'S?
26" diameter tires; 3.55 rear gears will be about 131 mph @ 6000 rpm in 4th
F
FastMatt
alamogordo nm USA
the rev limiter is at 6100-6200 rpm it seems, or is that just a tack thing?
Anthony - 98 GTS
Houston, Texas
Matt,
I would go with the 3.45 gear. The 3.55 will be pushing it with the power levels required to run a 10.50.
Marv S
Scottsdale, AZ
Matt,
rev limit is 6200.
check out the following gear page.
http://orbitdevelopment.com/viper/gears.asp
Plug in 3.55 gears and click on "manual" gear, plug in the 26" tires and then click on show gear chart.
a good discussion on shift points for Viper is at:
http://vca1.viperclub.org/ubb/Forum2/HTML/000203.html
<FONT COLOR="#ff0000" SIZE="1" FACE="Verdana, Arial">This message has been edited by Marv S on 06-17-2002 at 07:53 PM</font>
MES
Sarasota, Florida
One thing to also think about is that 135 trap will equal 140+ actual speed. The trap is the average of the last 60 or 120 feet (depending on the track) so you will run out of gear with 3.55's
