From what you DID NOT say, I'm guessing you have a 1992-2000 Viper...upper slide pin is 32 N-m (24 ft-lbs) and lower slide pin is 51 N-m (38 ft-lbs) per '95 and '99 service manuals. DIFFERENT DEAL with ABS !!!
For the front calipers...1992-2002 Vipers...tighten BOTH caliper assembly to steering knuckle attaching bolts to 115 N.m (85 ft. lbs.)...flex hose to caliper banjo bolt 31 N.m (23 ft.lbs.)
