GTSjbud
I am considering installing a twin turbo in my '96 GTS Venom 550 Hennessey. The twin turbo will put out anywhere from 900 - 1200 rwhp.
I want the option to drive my GTS in excess of 200mph. I would like to get close to 250mph...on the occassion.
Transmission
Should I upgrade the OEM transmission? I have heard from a couple of different sources that 5th and 6th gears **** for achieving max speed!
Are there any high performance T56 transmissions available for the Viper? If so who sells them?
Rear Gear Ration
What is recommended for a rear gear ratio to achieve 250mph with a twin turbo car running 355 25 19? What manufacturer is recommend for the rear gears?
**what should I target for a max engine rpm at 250mph? I understand that the Gen. II redline rpm is 6000.
I look forward to any input!
Cheers
Jason
Transmission
Rear Gear Ration
Cheers
Jason
