1TONY1
Background: Due to a hot cat burning the paint on the side sill I had removed the cats and replaced with straight 3" pipe. My exhaust was 3" with the stock cats reduced to half length and 3" Dynomax ultra flo race mufflers behind the cats in the side sills with 3" out the back....no muffler in the back.
The cat replacement 3" pipe caused the car to be a whole lot louder.....unbearable for me to drive everyday....maybe it was also the drone that was getting to me.
I replaced the 3" (cat replacement) pipe with Moroso race mufflers, with the Dynomax mufflers still on. This made my car as quiet if not quiter than before and the drone is gone. Inside the car the sound dropped a minimum of 3 to 4 decibels at different rpm's and part throttle acceleration. Yes it was so bad I bought a decibel meter to check before and after. The difference at two test points behind the car was 10 db. All tests were at the same spots, rpm, etc. They are 4" in diameter, 12" long body, 18" overall length. The stock cats were about 4 3/4" diameter and about the same length so they fit nicelyin the side sills. See them here:
http://www.moroso.com/catalog/categorydisplay.asp?catcode=35001
They also have 2.5" and 3.5" in/outs. Cheap easy fix at $90.00 for a pair. I have seen the flow in inches in the catalog....doesanybody know what stock or high flow cats flow in inches ?
