treynor
Upgrading your stock radiator to a thicker Fluidyne (or similar) while retaining your stock airbox introduces a clearance problem between the bottom of the airbox and the fan shrouding. This most commonly manifests itself as a growling or whirring sound once the car is warm, especially when the steering is turned one way or another. The problem is, once the fan shrouding is cut away to accommodate the airbox, the fan blades will contact the bottom of the airbox when the engine and/or radiator shifts slightly:
There are three basic solutions:
1) Replace the stock airbox;
2) Modify the stock airbox;
3) Replace the cooling module.
I chose option (3) because I wanted more cooling power when in traffic, and I wanted to retain the airflow and rain-resistant features of the stock airbox. Valaya Racing (408.448.8811) sells an excellent cooling module upgrade, and it has the side effect of eliminating the clearance problem associated with the OEM module and a larger radiator. I've included a few pictures to show how it fits:
Here you can see the space available with the Fluidyne installed and the OEM cooling module removed. Note also the stock oil cooler (that black thingie just above the brace).
Here is the "after" shot, with the two new fans replacing the stock single fan. Each of the new fans pulls as much or more CFM as the OEM fan alone, which really keeps the temps down in traffic.
A second "after" shot, showing just how much space is now available. I could practically get -two- airboxes in there
Needless to say, there is no more interference problem. A simple wiring harness plugs into the stock fan turn-on lead and activates the dual fans. Alternatively, you can wire it with a manual override switch to turn on the fans from inside the cockpit (good for drag racers) or using an external temp sensor.
obAside: my dyno testing has shown that, at least on '01 models, keeping engine temps below 190 picks up 10-20 RWHP compared to temps over 200. After tubes + filters, a radiator+thermostat+fan swap is the cheapest way to pick up real-world HP on the Viper.
