Upper radiator hose leak
1994viper
Toronto, Ontario
I developed a leak from an upper radiator hose. I have a pinhole leak and I was thinking if there is an easy way to repair it instad of buying a new one. The hose looks like its been repaired before, in the area besides the new leak.
what should I do? :confused:
Solid Red 98
Get a new hose. A pin hole leak means probable deterioration within the hose, unless it was caused by some sort of puncture. Don't play around when it comes to keeping a Viper cool.
Zentenk
I went to lowes and got some water pipe wrap, be careful as when it hardens the hose wouldn't stretch over the connection so I had to chisel away at the wrap to have the lower portion of the hose expand (top had pinhole leak). Don't bother buying a hose from dealership, the damn thing WILL NOT WORK! Only option is aftermarket hoses from Roe racing. With the wrap I ran the 1/4 mile 7 times and drove 1000 miles and it still holds up. It is only temporary, it looks ugly too haha.
bluesrt
go jump off a bridge, no go get a new hose.....:usa:
plumcrazy
ALL OVER
repairing a radiator hose is one of the most ******** things ive heard on this site in a while....buy a new one from tator or Roe.
heck even napa autoparts.
By my recollection, Dodge was out of Gen I upper radiator hoses over a year ago. There are other sources as stated.
1994viper
1994viper
Toronto, Ontario
Fixed and fixed. Found a great product at a local hardware store. Fiberglass, high-presure, water pipe wrap, rated for up to 300psi. :)
Now I can spend time on finding a cheap original part.
Thank you all
