Early93Viper
I am using a pressure tester to check and see if I have any coolant leaks. Per instructions from the manual I pumped the pressure tester up to 15 PSI and waited for two minutes. Again Per the 1995 manuals instructions if the PSI doesn't drop more than 2 PSI in 2 MIN than I don't have a leak. It dropped barely a millimeter (Maybe 1/4 PSI) in two minutes. And no visible leaks from any of the hoses. But I still thought that was weird it should be able to hold the pressure for 10 Minutes without dropping at all. So I pumped it up several times and timed the result every time I got the same figures. The pressure drops 1 3/4 PSI in 10 minutes. I got the same numbers when I pumped it up to 18 PSI, 17PSI and 16PSI.
First Question: Am I okay with a 1 3/4 PSI pressure drop every 10 Minutes?
I then started the car wet to operating temp (190-200) with the pressure tester attached. Pumped it up to 15 PSI. And the pressure tester was gaining pressure so I turned of the car.
Second Question: Did I perform this test right?
Thanks in advaced for the help.
-Dan
-Dan
