Sure. One of the first things I did. I connected it to the same power as the stereo head unit (two screws to pull the head unit), mounted the "accessory block" under the dash, used black telephone wire ($7 at target for something like 20 to 50 feet), ran the wire under the dash to the left side of the inside windshield, tacked it down to the inside edge of the windshield using clear silicone "caulk" - the wire and caulk is totally invisible and the power is switched (unlike if you connected it to the rear-view mirror power). I mount my Valentine-1 using the suction cup mount above the rear-view mirror for maximum distance and "view", and used a remote display on top of the steering column to make the display not obvious outside of my RT/10 when the top is off.
Make sure you leave a fair amount of slack up near the rear-view mirror, as I remove the detector most of the time when I leave the car, and thus I wear out that connector. If you leave a fair amount of slack, you can cut off the worn-out connector and replace it very easily many times, although each time you lose about 3/8" of the wire.
