Valves
Goodie, a QUIZ !
Intake: 1.92"
Exhaust: 1.58"
Length: 5.726"
[ PartsRack can offer you OE; or street-performance Oversize: 2.02 0r 2.10 intakes, with or without longer stem lengths........1.60 exhausts
Viper Wizard
South Salem, NY USA
COMPLETE DIMENSIONS:
Face Angle.........44-1/2~~45deg.
Head Diameter Intake....1.915~~1.925in
Head Diameter Exhaust....1.575~~1.585in
Lenght Intake[Overall]....5.713~~5.738in
Lenght Exhaust[Overall]....5.757~~5.782in
Valve Margin Intake....0.051in
Valve Margin Exhaust....0.080in
Lift Intake[Zero Lash]....0.541in
Lift Exhaust[Zero Lash]....0.541in
Valve Stem Tip Height....1.929in
Stem Diameter Intake and Exhaust....0.311~~0.312in
Stem-to-Guide Clearance Intake and Exhaust....0.001~~0.003in
Max. Allowable Intake[Rocking Method]....0.020in
Max. Allowable Exhaust[Rocking Method]....0.027in
Viper Wizard
South Salem, NY USA
VALVE SPRINGS:
Free Length Inner[Approx.]....1.913in.
Free Length Outer[Approx.]....1.978in.
Spring Tension[Valve Closed]:
Inner....38-42lbs. @ 1.509in.
Outer....61-65lbs. @ 1.709in.
Spring Tension[Valve Open]:
Inner....96-104lbs. @ 0.984in.
Outer....192-208lbs. @ 1.184in.
Valve Springs Number of Coils:
Inner....6.9 Left Hand Twist
Outer....5.5 Right Hand Twist
Valve Springs Wire Diameter:
Inner....0.132in.
Outer....0.192in.
Installed Height[Spring Seat to Bottom of Retainer]:
Inner....1.457in.
Outer....1.657in.
The 2.10 Valves-Don't know?
Hope this has helped Steve
sham5430
