tristan rizzi
Someone PLEASE HELP me......
My 94 has been completely rebuilt (with LOTS of mods) and is not running right. It appears that the computer is staying in an open loop and not delivering the correct A/F mixture. On initial engine start-up and run in on the chassis dyno it looks good for over 500RWHP but without the correct fuel delivery we cannot test the car. Adding to the issue is that I am in Japan for a year. The car is at the Dyno Shop in San Diego!!! Does anyone have any ideas as to what might be wrong??? The engine has the following mods:
Honed Intake (4 rib) w/t 68mm Throttle bodies
Smooth tubes & K&N filters
1.7 rockers (full roller)
Stage III heads
Light weight coated pistons (stock compression)
Lightweight HIPO conrods
Hi energy Cam
Headers
3" Pipes (no Cats)
Full balance & blueprint
Aluminum flywheel....etc
At this point the engine builder and instaler are sure that the engine is sound, and that the problem is fuel delivery related.
Everything has been checked, and is correctly hooked up - any one have ideas??? Should I just have the car put back into my garage and take it to a viper specialist when I get back to the States??? Thanks for ANY advice offered
Tristan
Stage III heads
Hi energy Cam
Headers
3" Pipes (no Cats)
Tristan
