Well, actually, I'm abougt 135 lbs and a 15" neck. It cuts me too. They do make some pads you can put on that make it more comfortable. Sometimes I ran the inboard belt around the seat instead of through it. I don't know how safe that is though, so can't really recommend it.
ANDY -
YOU CAN RUN BUT YOU CAN'T HIDE!!!
295 LBS - 6"1" - BIKER
I also installed the 1" lowering kit since my head hit the roof with a helmet on. However, I do not think the new angle from the bolster is the problem.
Is it within the rules to bring the shoulder harnesses around the side of the seats as ANDY suggested??
I would NOT recommend doing that, HOGDEALER...if I envision your suggestion correctly, would fear LACK of proper restraint, and INCREASED risk of injury...also doubt you'd pass tech inspection...just my opinion an occasional "track doc" in former years.
I had the same feeling around the neck, they do loosen up when broke in. Use a collared shirt as mentioned above. Or better yet a Hans Device will take car of your worries of a neck rub.
