Viper Engine Calibrators Now Available For 1992 to 1995 RT/10's..
Sean Roe
Jacksonville, FL
Viper Engine Calibrators Now Available For 1992 to 1995 RT/10\'s..
Hello Everyone,
Roe Racing is pleased to announce that we now offer the Viper Engine Calibrator (VEC1) system for 1992 to 1995 RT/10's. On stock engines, ignition timing and fuel calibration changes yields improved part throttle power, throttle response, driveability and power curves. On modified engines, the calibrator and accompanying air / fuel ratio gauge will allow you to tune in your engine to get the most out of your modifications. Power gains depend on engine configuration and settings, but can be as high as 30 lbs of torque at part throttle loads (can be seen on a Clayton dyno).
As with our 1996 and newer VEC1 systems, this model year application will carry a 6 month warranty and 30 day money back satisfaction guarantee. Easy installation into the factory wiring harness requires no special tools and can be done in about an hour. Comes with a color installation / user manual and full customer support. In stock and ready to ship.
Introductory priced at $449.95 for 1992 to 1995's. 1996 and newer on sale for the same price during this month (regularly $495.00)
To place an order or inquire about this product, simply e-mail or call us at the shop. (904)-733-5469
To learn more, go to Roe Racing Catalog
Thanks for reading,
Matt
San Jose, CA
Re: Viper Engine Calibrators Now Available For 1992 to 1995 RT/10\'s..
Sean,
Do you happen to have any improved HP/TQ numbers that a gen 1 engine will see?
Thanks,
Matt
Sean Roe
Jacksonville, FL
The answer to that question really depends on the modifications to the car. "Stock" 1992 to 1995 don't seem to run as rich as the 1996 and newer Viper at full throttle, and need less of an adjustment to optimize full throttle power. Part throttle power has the largest gains (#'s posted above) and took more of an adjustment than 1996 and newers. At full throttle, on a Dyno-Jet brand dyno, a stock '94 with smooth tubes and filters had peaks of 395 rear wheel HP and 477 rear wheel TQ with the calibrator on and set to improved street performance settings.
Each car is going to vary a bit, so we include a 30 day money back guarantee so that people can try it out and see how they like it. We're very confident in our product and its ability to modify the performance of the car.
Puntacanaviper
