Viper HVAC
2tall
Royal Oak, MI, USA
Alrighty, so I'm looking through my operators manual b/c I thought that the HVAC was acting odd. It seems that's not the case (it's supposed to have a binary tempature setting).
However, I'm a little confused. Let me know if this is the right understanding -- confirm or deny (starting with the leftmost icon).
Recirculate-A/C:
Mixes inside and outside air. Uses A/C, Cold (full cold) only.
A/C:
Outside air only. Uses A/C (duh), cold only.
Panel:
Outside air only. Doesn't use A/C, allow temp adjust???
Off:
Uh...
Floor:
Outside air through floor and defrost. Doesn't use A/C, allows temp adjust???
Floor/Defrost:
Outside air. Floor and defrost even mix. Uses A/C, allows temp adjust???
Defrost:
Outside air. Defrost only. Uses A/C. Allows temp adjust???
Many thanks!
2tall
Royal Oak, MI, USA
So from left to right:
A/C-cold, A/C-cold, engine temp air - face level, off, engine temp air - foot level, A/C-adjustable, A/C adjustable.
Thx! Another mystery solved.
shifter
Novi, Michigan
The recirc takes interior air only, allowing for max A/C performance. 'Panel' is like 'vent' - outside air. You can heat it up, but not make it cooler (won't trigger the compressor).
Correct about floor, hot only. Defrost allows hot and cold. Need the A/C in defrost to demist and defrost the windows.
I believe that the A/C doesn't allow much temp adjustment. Basically it blows full cold, as you can't turn on the A/C and open up the water valve at the same time to warm up the A/C air going over the heater core. I'm 90% sure about this.
Cold, warm, cold, warm, cold, warm..... not a good car for temperature sensitive people.
CitySnake
Manhattan, USA
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by JMcGuire:
And "outside air" seems to be "outside air from inside the hot engine bay".
<HR></BLOCKQUOTE>
JM: YOU CERTAINLY GOT THAT RIGHT!
We need shoe outlets for perspiration drain.
