Sam Goldfarb
Recalls & TSBs
You can check for any brand/make at:
www.alldata.com
Remember you can only see the titles, not the text, unless you subscribe. Take the title to your dealer for a printout!
Viper Recalls and TSBs Quick Links: I didn't look up both the RT/10 & GTS models when they were available, if you have the model that isn't listed when you click the link below, start at the www.alldata.com link and follow the prompts. Usually the info is the same for both model Vipers. Happy Hunting!
1992 http://www.alldata.com/TSB/16/92162039.html
1993 http://www.alldata.com/TSB/16/93162039.html
1994 http://www.alldata.com/TSB/16/94162039.html
1995 http://www.alldata.com/TSB/16/95162039.html
1996 http://www.alldata.com/TSB/16/96162039.html
1997 http://www.alldata.com/TSB/16/971677EV.html
1998 http://www.alldata.com/TSB/16/98167839.html
1999 http://www.alldata.com/TSB/16/991678EH.html
2000 http://www.alldata.com/TSB/16/001678EH.html
2001 http://www.alldata.com/TSB/16/011678EH.html
2002 http://www.alldata.com/TSB/16/021678EH.html
2003 http://www.alldata.com/TSB/16/031685F6.html
2004 No Listing At This Time
You can check for any recall or TSB ( Technical Service Bulletin) at www.alldata.com You can only see the Title, unless you subscribe to their service, but if you have a friend that is a mechanic or the local DC service guy, give him the number and they can print it out for you. Recalls are eventually sent out to the last known owner of a vehicle. The TSBs are sometimes kept "Secret" under the don't ask don't tell program! I have "surprised" my dealers occasionally with the solution to the problem I have!! You may not always see a direct TSB for the problem you are having, for instance there is one for 97 Vipers that references Rough/High Idle. The factory fix was to replace the intake manifold gaskets. Most found that even after they did this the " Idle Hang" was still there. So, these are not gospel but help a lot of the time. I have listed the quick links, by year above, to see the info. I will post the links somewhere else on the VCA Forum, as the info might help a lot of members !!
Here is a typical printout for 1994:
Service Bulletins
TSB Number Issue Date TSB Title
1. 19-001-01 MAR 01 Steering - Loose Feel/Clunking on Turns
2. 09-04-00 FEB 00 Engine - Replacement Break In Procedure
3. 26-10-99I OCT 99 ABS - Kelsey Hayes EBC-5H, EBC 310 Test Revisions
4. 08-23-99 JUL 99 Radio Communication Equipment - Recommendations
5. 08-36-98 JUL 98 Auto Computers - Y2K Effects
6. 21-06-98 APR 98 M/T - Gear Noise Explanation
7. 23-59-97 NOV 97 Rocker Panel - Corrosion
8. 23-41-97 JUL 97 Convertible Top/Side Curtains - Water Leaks
9. 22-01-97 JUN 97 Tire & Wheel - Runout
10. 08-14-97A JUN 97 Battery - Premature Failure
11. 07-03-97 MAY 97 Engine - Coolant Recommendations
12. 090397 APR 97 Dipstick & Tube - Service Applications
13. 23-03-97 FEB 97 Black Plastic Body Components - Chalky Residue
14. 050996 OCT 96 Brakes - Noise Explanation
15. 181896 MAY 96 Throttle Cable - Lurching/Idle Undershoot/Noise
16. 260795 SEP 95 Service Manual - Revisions & Updates
17. 030495 JUN 95 Drive Line - Clunk on Acceleration/Deceleration
18. 232095 MAY 95 Soft Top to Windshield Frame - Wind Noise/Water Leaks
19. 082295 MAY 95 Radio Transmitters - Installation
20. ATRATB294 JAN 95 A/T - Drive Axle and Wheel Lug Nut Torque Specifications
21. 260494 OCT 94 Diagnostic Manual Catolog
22. 241394 SEP 94 R 134A Refrigerant - Leak Detection
23. 180094 MAR 94 TSB - Group Change
24. 081194 FEB 94 Electrical Connectors - Cleaning Precautions
25. 092093 DEC 93 Engine - Service Procedures
26. 242093 JUL 93 R 134A Refrigerant - Leak Detection Systems
27. ATRATB078 NOV 91 A/T - How To Use A Pressure Gauge
28. ATRATB028 OCT 90 A/T - Engine Vacuum Testing
29. ATRATB9002006 FEB 90 A/T - Choosing the Right ATF
30. ATRATB8930 OCT 89 A/T - Math Part II
31. ATRATB8927 SEP 89 A/T - Twenty Steps To Successful Repairs
32. ATRATB8923 AUG 89 A/T - Math Formulas Part I
33. ATRATB8754 SEP 87 A/T - Front Bushing Wear
34. ATRATB8748 AUG 87 A/T - Slipping or No-Shift/Metal Sealing Rings
Regards!
Sam Goldfarb
OHIO VCA Secretary
www.alldata.com
Service Bulletins
Regards!
Sam Goldfarb
OHIO VCA Secretary
