What do you guys use to get tar off the side sills?
BigsViper
West Texas, USA
Adam, Use some WD-40 on a 100% cotton towel, then wash right away and reapply Zaino. Also works great for the gunk on the back bumper and rear facia.
red98GTS
Arizona, USA
Ditto what Bigs said. WD-40 used without rubbing to hard and an immediate clean up is about as good as any "tar remover" you can buy. WD-40 also works as a great adhesive tape residue remover, in case anybody ever needs to get that junk off of anything. Apply enough to really wet it, let it soak in for a minute or two, then wipe carefully. pete the ex glass guy
Russ M
LA, California
The best products to use are bug and tar removers, there are several on the market and they all seem to work the same. They will not harm your paint and may take more than 1 time if the spot is persistent.
Another good product is Meguires paint and body scrub, this stuff will remove anything that does not belong on the paint. If it does not remove it, then it just cant be done.
