Re: Which do you think takes more skill Road Racing, Autocrossing, Drag rac
Look at the driver task:
Drag Racing
1.Burn-out
2.Staging
3.XmasTree reaction
4.Launch
5.Shift
6.Shift
7.Shift
8.Duration 11-12 seconds
Autocross
1.Staging
2.Launch
3.Shift(depends on layout)
4.Brake(depends on layout)
5.Turn(20 to 70 MPH, depends on layout)
6.Duration 50-70 seconds
Road Racing
1.0 Launch may or may not be a factor depending on event
2.0 Shifting
2.1 Up to 4th or 5th depending on track
2.2 down 5th to 1st depending on track
2.3 repeat 2.1 and 2,2 as required
3.0 Braking for turns 10 to 15 typical, speeds 40-150 mph
4.0 Turns speeds 40-150 mph
5.0 Duration 15 to 30 minutes typical
6.0 Cabin Heat Factor
7.0 Traffic
7.1 Passing doing or being
7.2 Car on your bumper at 40 to 140 mph
Seems pretty easy to evaluate when looking at the task.
Drag Racing reaction to XmasTree, Launch and shifting a three times and you are done. Max speed 118-123 mph
Autocross require launch and typically one shift, relatively low speed car control max. speed 70-80 depending on layout. One lap of 50-70 sec. typical
Road Racing Highest Maximum speeds, More braking skills, higher speed turns, shifting up approx 12 times per lap down shifting same. Repeat for 15 to 30 minutes. Now add 15-30 cars to the track.
In my opinion Road Racing is 30 to 100 times more demanding than an Autocross and 1000 times as demanding as Drag racing. Depends on your view of shifting, braking speed, Turn speeds, maximum speed and activity duration and traffic.
