Who is running the most Nitrous on a creampuff ?
Catwood
I ran a fairly big shot
I can look up the jet size later if your interested.
Carl
J DAWG
MS
only a 100 shot for wimps like me. :laugh:
TNT #39 nos and #22 fuel
Catwood
I think I was a 55N 42P but need to confirm. Propane jet can only be so big.
VIPER006
Miami, FL
I am running an NX 200 shot on my creampuff. But I did finally end up going with colder plugs and a tighter gap. When the nitrous comes on it feels very strong now. Before, I had the same shot without changing the plugs or gap and did not feel the nitrous at all. The change was worth almost half a second in the quarter, 0.44 seconds to be exact. The only difference was the plugs' temp and gap. Hope the info helps.
J DAWG
MS
anyone getting misfire codes on 2001 or newer cars. Related to the colder plug?
Cudaman
USA
John what brand of plug are you using and it's number?
Cudaman :usa:
VIPER006
Miami, FL
J Dawg
I had major misfire problems when I bought the car new. The first was at about 450 miles and was a 5 cyl. misfire. It happened about 3 times more after that. Not to drag on, it turned out to be my pcm. Once changed, never a problem again.
As far as the new colder plugs, not one issue. I am running NGK's, not sure on part #. But if anyone really wants to know tell me and I'll look at them, then post it.
J DAWG
MS
I am running the autolite 3923's as well. At cruising rpm's I will get code 300 and 302(cylinder 2). I need to pull the plug and look. Been too lazy thusfar to do so.
What are some other plugs people use?
John
