WTB: Used, "Junk", Engine parts
Fusion Works
Huntsville,AL
I am looking for a few used, worn out, damaged Gen 3,4 and 5 engine internals. I need one or two rocker arms. Could use a Gen 4 sodium filled exhaust valve for testing. I need a couple of valve springs, preferably intake and exhaust. (just need to know what they came from). I think I can use all generations on the valve springs.
Could use a 3.96in stroke crank, if its damaged or worn (cheap). Need to mock it up for use inside a Magnum V10 engine. These parts don't really need to be usable, but do need to be measurable and hopefully retain most of the OEM dimensions.
Could use an OEM two barrel TB for testing purposes. I can make my own flange to weld onto the Magnum intake manifold. (I am not sure this throttle body isn't too big)
Brett W
I have a bunch of springs, mostly Gen 2/3. Crank is tough, but I have one, still good.
