5245322 PCV Grommet NLA / Substitute
Suregrip391
Niagara Falls
Hi Guys, I always try to do as much homework on my own as I can, does anyone know if this is the correct Dorman PCV Grommet for a Gen 2 Viper? I would like to have one on hand for the day I need to pull my intake and change my T-stat. Specifically for my 97 GTS
OE Number 5245322
Dorman Number 42064
if Anyone can confirm the fit and size of an original as they do look the same? Open both attachments to see…..
Chrysler Corporation has used exactly the same grommet for every car in their line since 1967. The ONLY difference for the Gen 2 is that it has a double-male barb pushed in from the backside. The Dorman part is good to go. They also make a replacement for the hose from there to the PCV valve. It may be too long, but that's just because in '98 Dodge did away with the standard valve and went with an orifice restrictor in the tee. Just cut the excess off.
Do you track your car at all, or just street drive?
Suregrip391
Suregrip391
Niagara Falls
Hi Dean, thanks for the info here, just street driven…..I’ll have to see about tracking that part number down for the hose….
Mpcc
