643whp/606wtq: Greg Good Heads/Cam with A&C Tune
345s-bspinnin
Houston, TX
SHORT STORY:
Decided to go heads/cam route on my SRT. Quick searching pointed me to a gentlemen residing just up the street from me. I knew there was some power to be realized by porting OEM heads, but end results blew my mind. This relatively straight forward application of Greg Good Heads, cam, full exhaust, and remote tune by Todd at A&C produced gains of almost 230whp at redline!!!!
DETAILED STORY:
Its a novel. Grab some coffee or a beer and sit down for this one. Plenty of information enclosed, including pictures, tables, charts, graphs, and videos.
MODIFICATIONS:
- Greg Good ported OEM Heads with Greg’s recommended valve train components (2.02/1.60 valves, springs, retainers, slow-bleed lifters, etc.)
- Greg’s trusty Comp Cams Grind 3634/3635, 232/236, .601/.606 valve lift at .050 on 1.7 Rollers
- Port matched Intake Manifold (just runners, not cut open or anything like that)
- T&Ds Roller Rockers
- Rear head cooling modification for decreased thermal gradients along heads
- Final compression at 10.5:1, (heads decked, thinner head gasket)
- Exercised proper due diligence with build, including cam degreeing, injector flow cleaning/testing, precise pushrod measurement, spark plug indexing, new AB wires, etc.
- Includes cosmetic upgrades like polished intake manifold, powder coating valve covers/spacers
- Peterson Fluid System Catch can (same as ACR-X) with Exotic Engine style valve cover adapters
- X-Metal Throttle Body with CAI
- Stock short-block, fuel system, clutch, ignition, damper, etc.
TUNING:
- SCT Software
- Remote tuning by Todd at A&C Performance
- Took more than a couple of iterations, but Todd did a fantastic job of tuning from 2500 miles away
LABOR:
- I took the DIY approach; all parts removal and installation tasks done by me in my home garage (service manual, basic tools, car on jack stands, uhhhh courage?)
- Working on a Viper was new to me. However, this was not my first rodeo and the Viper is certainly not a spaceship. All work was relatively simple and straight forward.
- Cost is free; if we choose to ignore opportunity cost, and numerous cases of beer I went through :)
ISSUES:
- American Racing Headers would interfere with ARP Head bolts; flange had to be recessed for proper clearance (see pix below)
- Mystery o-ring found in oil pan. Anyone know where these came from (pic below)? Apparently car was built on a Monday.
- Random/weird PCM Failure after a SCT tune upload. Haven’t quite pinpointed the issue, but we suspect the email system or anti-virus corrupted the file. SCT was able to recover PCM via a recovery file. Thanks to Todd at A&C performance and the folks at DC Performance for getting me quickly on the road again and in time to participate at the Texas Mile
PRICE $$$$:
- Total cost, including porting OEM heads and ALL other related parts including catch can, x-metal throttle body and air intake system is on par with the price of a new Paxton as priced at Summit Racing
- Full-exhaust (ARH and ACR-X Catback) costs are separate
RESULTS: (Dynojet dyno, and results all SAE corrected per industry standard, before/after charts below)
- Peak gain in hp: OEM 446whp vs. 643whp (+197 whp gain at peak)
- Peak gain in tq: OEM 500wtq vs. 606whp (+106 whp gain at peak)
- Hp gain at redline: OEM was 415whp vs. 643whp at 6200 (+228whp gain at redline)
- TQ gain at redline: OEM was 365 wtq vs. 544 wtq at 6200 (+179wtq gain at redline)
- Peak number of 643whp/606 is about 756bhp/716tq at the flywheel with (15% loss)
- 50+% improvement in power
REAL WORLD (for the anti-dyno folks):
- I haven’t been to the 1/4 mile track, and won’t be until there is a private rental since I have no plans on adding a full cage for my vert
- I was already running 11.5 at 125 with only headers/tune on street tires, I am certain that I will be well into the 10s now
- I participated in the Texas Mile. Ran 191.5mph and was doing over 134mph by the 1/4. This was on my 614whp/590wtq setup. See my Texas Mile thread for more info.
OVERALL IMPRESSIONS, OBSERVATIONS, and COMMENTS:
- I am flabbergasted that a relatively simple Greg Good heads/cam package, hi-flow exhaust, TB/CAI, and a good tune from Todd at A&C Performance can gain a peak of about +200whp
- 750 miles since build with no mechanical issues (includes many many WOT hits needed for tuning), and numerous healthy long-winded runs at the Texas Mile
- Valve train is surprisingly quiet for T&Ds (about the same as stock, maybe even quieter)
- More “buckin’ bronco” at low rpm while in lower gears, occasional idle hang (while computer was relearning, now appears gone)
- No major issues with reversion, I can still cruise at 40mph in 5th, rpm at ~1100rpm
- Engine exhaust was louder, even with my OEM exhaust with crossover (ARH w/o cats)
- Engine sound turned absurdly louder with ACR-X catback, decelerating popping is more prevalent
- Power gain is very linear; oddly enough, very similar to a centrifugal blower
- On the street, it’s an absolute rabid animal. It will spin through most of second gear if you stab the throttle anywhere between 30-75mph. Must roll into it now :)
- I have received many compliments on the lopey sound at idle, it literally rocks the car
- No check engine lights, and all readiness tests complete, except 1 – EVAC
- This means I can successfully pass OBD-II Emissions testing in Texas since we are allowed 1 non-complete readiness monitor
TO THE GENTLEMEN BEHIND THIS WORK:
I would like to give out a HUGE thanks to Greg Good. He is a vault of Viper engine knowledge. His work is absolutely phenomenal and proof is in the numbers. Also a HUGE thanks goes to Todd at A&C Performance for being my one-stop-shop for the engine build (tune, parts, gaskets, spacers, etc.). I must tip my hat to Todd for doing a great job of tuning my car remotely. He was instrumental in helping with my PCM woes and allowing me to make my Texas Mile event. Thanks to Mark at Woodhouse for helping me with the other “while you are there” tasks such as replacing leaky power steering lines, leaky oil cooler lines, ripped shifter boot, new trans/diff/brake fluids, failed shock replacement, etc. Lastly, thanks to Mr. Chuck Tator (Wizard) for being my guiding light with some of my noob questions.
DYNO RUNS:
Results (SAE corrected, smooth at 5). Best was 643whp/606wtq. Other dyno runs are are part of my throttle body and CAI study. See next post below.
BEFORE/AFTER:
Comparison of Baseline (OEM) versus Heads/Cam Dyno Numbers
BEFORE/AFTER per RPM:
Gains across the RPM Range between Baseline versus Heads/Cam. Very linear gains!!!!
PORTED OEM HEADS:
Great eye candy for the gear heads:
Intake Port:
Exhaust Port:
Head Deck:
Assembled head:
Mystery O-ring Found in Oil Pan. It was just sitting on the windage tray/baffle !!!!!!!!!!!!!
American Racing Headers and ARP Interference: (header flange had to be ground down)
ACR-X Exhaust vs. OEM Cross Over:
Inside ACR-X Muffler:
View with OEM Throttle Body and Air Filters:
ENGINE BUILD VIDEO:
I had a Go Pro mounted on my cabinet as I did my engine work. Its starts with the car rolling into the garage and ends with a dyno run. I had set the GoPro to take a picture per minute. I simply would turn the camera on when I would get into the garage, and shut it down when I was gone. I took over 3000 pictures, which means I spent more than 50hrs of actual work doing something “constructive” in the garage. The next 6 minute video shows the conglomeration of my engine build pics and some videos (excuse my presence in some of those shots).
http://youtu.be/pjgTO8BtXNs
345s-bspinnin
Houston, TX
As part of my Heads/Cam work, I wanted to have proof that these single blade throttle bodies and fancy filter setups are living up to their hype. I contacted a local VCA member (Slithr) and scavenged parts of his car for testing purposes on my setup. I spent some time (and money) on the dyno doing back-to-back runs while altering the vehicles air induction piece parts. Hopefully my findings below will help you with your decisions in purchasing these bolt-ons. Big thanks to Alan (Slithr) for helping me with this study.
RESULTS:
All runs done on my Heads/Cam Car:
614whp/590wtq – [Blue line] Stock throttle body and OEM air filter setup
632whp/597wtq – [Red line] X-Metal TB and with OEM air filter setup (+18whp/+7wtq gain over OEM)
643whp/606wtq – [Green line] X-Metal TB and cold air intake system (+11whp/7wtq gain)
Results show that both of these components do show appreciable gains in power on my heads/cam setup. The combined addition of X-Metal TB and cold air system shows a gain of 29whp/14wtq over the OEM throttle body and air intake system. Power gains will be lower on engine setups that require less volumetric flow, but I have proven that there are gains to be had even on OEM setups.
Dyno sheets and pics (same as above):
Picture of Final Setup:
Atppilot
Really nice to see that more are going this route. Those are indeed impressive numbers and idle/real muscle car sound as bonus!!!!!
TowDawg
Chattanooga, TN
That is exactly what I would like to do, but I don't have the knowledge (or balls) to do all the work myself, so the price really skyrockets on me. Taking the intake and valve covers off is as far I would be willing to go myself. I am thinking about doing the ROE cam after seeing Twister's results. I don't "think" the labor on the cam would be all that bad.
Hats off to ya, because that is a serious beast now.
Daxzz
Thank you for the very detailed post. IMPRESSIVE numbers. Congratulations and enjoy it!
Slithr
Friendswood Texas
The lope is just plain Nasty! I also think the valve train is more quiet than my bone stock Gen III, great job dialing it in Andres. Great work Greg, I hope to have you fire that mill up for me one day :)
ssjcreeper
Ohio
Wow! Awesome, detailed information, and incredible results. Still can't believe what Greg can get these Gen 3's to put down with his heads/cam package. I'm still a few weeks away from wrapping up my build, hoping to see similar results.... damn this makes the wait sooo much harder. Great post!!!
Moundir
Ny
Great job, and congrats on those insane #s from a heads/cam build!!! Wow! Enjoy :drive:
FastMatt
alamogordo nm USA
I tell you what I would love to see a gen 3 with a big cam and a max ported set of gen 4 heads would do. Seeing how Greg has gotten gen 4's to make mid 600's with a stock cam and a ECU that cant be tuned.
Could we see 700+ N/A RWHP?
SlayerLS1
MD
Great times for an NA car. 134 mph is a healthy trap speed. Anyone wanna chime in on how paxton vipers trap?
FLATOUT
125-132 on stock builds in varying DA, some might have run 135, but I know this setup will walk a stock motor Paxton car. If it trapped 134 in 1900 DA it should trap high 130's or even up to 140 in negative DA.
Twister
I was gonna go with roeraceing ported heads to match my 710 cam.
But your 643 is insane. Thats 700 hp crank!
Now I wanna go your route...Ive only got 543 sae right now. That extra hundred rwho must feel incredible
ACPERFORMANCE
Murrieta CA
Thanks Andres. It's always good when I work with somebody that has as much mechanical ability as you. In addition to a good parts list on your car with the right people doing the heads and cam :)
Todd
A&C Performance
FLATOUT
Todd
A&C Performance
Todd he mentioned your professionalism on more than one occasion. Good work!
ctrengine
