are there any good performance chips for the 93-95 viper?
bigr1
Pittsburgh, PA
does anyone know of a company that produces any aftermarket performance chips for the viper that work???
Sean Roe
Jacksonville, FL
With OBD systems, you really don't have "chips" anymore that you can plug in and test.
You really have two options:
1. PCM reflash (reprogram), which is great if you know EXACTLY where to set the mapping.
2. An OBD system compatable "calibrator" which allows you to adjust the load calibration (shown as a percentage when using a scan tool), thus adjusting the air fuel ratio and ignition timing. This can be an extremely effective tool to use on Vipers and other speed density system cars where they are programmed to otherwise run very rich with little spark advance at wide open throttle.
Here's a link to our website which shows what we have to offer in the way of a calibrator. http://www.roeracing.com/index.html?token=974781757-1144410167-1631977245&A=24&B=Viper%20Engine%20Calibrator . Otherwise, I'm not sure if there's anybody out there doing reflashes on the dual PCM's the 1992 to 1995 uses. 1996 uses 1 PCM and is OBD2.
kverges
Dallas, TX USA
Correct me if I am wrong, but I do not thinkg '92-'95 PCM can be reflashed and the chip is "potted" in epoxy.
Dan Cragin
LA, CA
We are one of the few that reprogram these early SBEC engine computers. All we require is a list of your modifications. For those of you with highly modified engines with cam changes and bigger injectors we can really help improve the way your car runs.
Mpcc
