Roe Supercharger VEC3 95 octane
morell
NORWAY
I am from Norway and have a Roe Supercharager 8psi.My car is a 1994 rt/10 without air-condition. Can anyone please help me to program the VEC3 for 95 octane. 95 octane is the normal fuel here in Norway. I got 2 cards from Roe when I bought supercharger, but I think it's for 91 and 93 octane.
Can you give an instruction what I shall adjust in the VEC3 program. I have a laptop and can plug in to the VEC3
I have mailed Roe, but i have never got a answar from they:brick: :grumpy:
ViperBing
Eastern Shore of Maryland
Check out the Gen II section of this tuning forum. Lots of good tuning info there from Damn Yankee. Roe's directions are pretty good too. You really shouldn't make any changes to the VEC3 programs without a wideband 02 sensor.
dansauto
gillett, pa, usa
you will be fine using the programs sent with 95 octane. Its when you go down in octane that you have to be careful. You may be short a little Hp as you could increase the timing with the higher octane, but dont try this until you have a wide band on the car.
Madduc
Fremont,MI
Also your 95 octane is measured differently than our 93 octane. The 93 card should be fine.
Mpcc
