Spark Plugs for 150 shot of Nitrous
ViperPWR
Orange Park, fl
What plugs would you recommend for a 150 shot of nitrous on a 2001 with a 710 cam and champion heads from Roe Racing? The car currently has stock plugs, would a colder heat range be a better/ safer plug?
Jack B
NE Ohio
If you are running 10.5 to 11.0 the stock plugs are fine. The problem is that the colder plugs probably will not be the extended reach, therefore, will not run that good on the street. On the other hand, at the track, one range colder will not hurt.
ctrengine
