Tuner in north Alabama or southern Tennessee
BLKSNAKE
Huntsville, Alabama
Hi- decided it was time to have my gen 3 supercharged viper professionally tuned
I went through a round of mods two years ago - dumped my vec -2 and external pumps (which had worked flawlessly) on a semi canned tune which I had locally confirmed for A/F ratios
Installed in tank pump, bigger injectors, corsa exhaust and my local guy did a SCT tune - not sure if it was custom but the Dino pulls looked good - probably a bit rich though
Problem was I often smell gas - no leaks - but plugs are black and runs real rough until
Warm - then all is good
Looking for an experienced SCT tuner to smooth out the cold idle and maybe lean the whole curve a bit
Also need to do something with the Paxton belt tensioner -
I found a shop called Speed South in Pellam - don't know anything about them
Rich
Larry Macedo
Sanford, FL
Hi Rich,It's very possible your stock Gen III exhaust manifolds are cracked. When this happens upstream of the upstream oxygen sensors, oxygen is sucked into the stream and causes the oxygen sensor to read the mixture improperly, telling the PCM to add fuel to a lean mixture. This is becoming an ongoing problem. The cracks are hard to spot with the exhaust manifolds installed due to the location and the heat shielding.It's also possible your tune is too rich in that map/rpm segment and needs to be leaned out a bit.
CWhiteRun
Has Left the Room!
Dothan, AL
Thanks Larry - I had assumed that with les than 9k miles my manifolds were good - but what you said makes a lot of sense - I will check them out
You're best bet to to take a vacation to Orlando, drop the car off with Larry in Sanford and go to Disney. He will have you fixed and tuned for the ride home. :thumbs2:
Mpcc
