What point on the frame do I measure ride height from?
CRIT
San Jose, CA
Hi all, looking to adjust ride height to rough track setting in the ACR setup guide. It mentions the frame rail. Should I measure from the bottom of the V jacking points front and rear or to the bottom of the car frame right next to the jacking points or on the inboard frame under the suspension points? Thanks!
As I recall from the manual I was pretty sure you were supposed to measure at the frame rail by the suspension. I think more specifically you are supposed to measure at the frame rail at the center of the wheels if that makes any sense. Basically draw a line between the front wheels and a line between the back wheels and go up from that line to the frame rail for each measurement.
