What would you Bring? To an Enduro
FrankBarba
If you were running a 2 - 4 hour enduro, what would you bring to the Pits?
Janni
Raleigh, NC, USA
Extra radios, lotsa ice and drinks, impact gun, spare front and rear tire, nitrogen tank for the jacks, duct tape, obviously all necessary fuel (figure out which jugs / spouts pour the fastest unless you are required to do 2 10 minute stops, etc)
We brought all this and more to the 8 hours that we did - but that was with 3 drivers, a 1996 RT/10 and that went through a whole lot more consummables that you will in a CC for that length of time.
Frank Parise
Tucson, Arizona USA
To add to what Janni said.... I hope you have a Cool Suit for the Enduro. If so, add ice to the cooler box at each pit stop. Depending on the track, you can run 60-70 minutes on a full tank of fuel in your CC. Bring your favorite windshield cleaner..another must at each pit stop. You can run the entire 3 hours on one set of brand new slicks. If you have to change a tire, you'll lose way too much time. Also, extra batteries for race radios may be needed and a well-prepared crew that knows what each individual's tasks are during the pit stop are critical. The most dangerous part of the pit stop is for refueling. It's easy to start a fire if some fuel dribbles out of the funnel and onto the rear brake rotor/caliper, so have a fire extinguisher handy. Also, you'll be lapping slower cars dozens of times, so run with your headlights on. Good luck.
FrankBarba
FrankBarba
Thanks all for your info. Finished the Enduro. Due to a long pit stop, finished 4th overall & 1st in Class. Great Time.
ctrengine
