Definately on the torque reduction...
http://www.cdegroot.com/cgi-bin/mirror/pweb.jps.net/~snowbum/sparkplugs.htm
This is waht the above link says...
The use of antiseize is somewhat controversial, mostly I think this is due to SOME spark plug manufacturer's literature.
There are probably two reasons to NOT use anti-seize compounds:
(1) Some experienced mechanics feel that it is then easy to overtorque and pull threads.....my answer is that one should be using a torque wrench, AND lowering the official torque (which is usually for use withOUT antiseize compound).
(2) Since the use of popular antiseize compounds acts like a lubricant, the applied torque MUST be reduced...about a 1/3 reduction is roughly correct. SOME manufacturer's are concerned.......with HEAT conduction....probably feeling that the heat range of the spark plug is changed by the use of the compound. I have NOT seen this in real life situations. I have always used some sort of antiseize compound on my own spark plugs...and I have close to 530,000 miles on airheads. I've NEVER 'pulled' spark plug threads out of a cylinder head.
Antiseize compounds vary in characteristics, but I have found NONE that are NOT OK at the spark plugs. ONE thing you do NOT want to do is use OIL!!!...and that includes WD40.....these will carbonize, and cause thread damage over a long period of time.
NOTE: ONCE antiseize is used, it tends to work its way into the aluminum head metal....from that point on, it is best to use antiseize.
Using oil or WD40 will tend to result in hard carbon deposits in the threads, and thus tend to wear the threads, and tend to change the effective torque. Some spark plugs seem to have a bit less diameter on the threads, and that promotes carbon and wear. That, and other problems has been reported on Champion..and other... spark plugs. Bosch tolerances seem to be better, and Bosch plates the threads, which helps avoid use of antiseize, if you are so inclined. Spark plugs that, upon a wee bit of loosening, seem tight, should be oiled...a penetrating oil (or Kerosene!)...allowed to soak, even overnight if need be; and possibly carefully tightened a bit first, if that is not overtorquing, and then removed carefully....to avoid damaging the threads. I have had to clean up carbon'd threads MANY times...a good fresh sharp 14 mm tap works wonders, and I use a bit of White Lead on the tap. I then clean the threads, leave the threads clean and dry...THEN I antiseize...a dab...not much....on the spark plug threads....when installing the new spark plug; and torquing properly. You do NOT have to spread a lot of antiseize onto a plug threads...and you want to totally avoid getting any on the ceramic tip area anyway, where it might electrically short circuit the plug. A wee dab, on a fingertip, spread into the threads is just fine. Try to avoid using a tap if you can, as....depending on thread condition...a tap can not only reform threads in soft material like aluminum...but can cut and remove material.
***The exact amount of torque to use:
You CAN do this by hand, no torque wrench, once you have a good feel for it, but use of the torque wrench is HIGHLY recommended. I've seen various forces needed to properly seat the crush rings. I suspect crush rings vary somewhat. Since we all know that many of you will not use fresh crush rings, the values I am giving here are generally safe values, with a drop of antiseize spread onto the threads:
3/4 reach, 14 mm, about 12 ftlbs. This is the stock top spark plug size.
1/2 reach about 9 ftlbs; this is the commonly used bottom spark plug size on dual-plug conversions;....which is USUALLY just enough to seat the washer and a tad. I'd prefer less on the 1/2 reach, say about 7, but this may well not be enough to ensure a positive seating. In fact, it may barely be enough on a already used crush washer. You can try. Be careful. JUST snug is right. You don't want the plug too loose either...if it loosens and rattles out, that pulls/wears threads.
NOTE: with no antiseize 'ever' used on your heads, you can torque to spec.
