So, i bought a supposed 04 block/crank (same bore/stroke, crank trigger not an issue) with the thought of putting in a set of 05 pistons/rods i had (verified to be 05 pistons/ rod). Same part numbers 04-05 so should be no problems.
After installing a piston/rod, the crank end of the rod completely contacts the oil galley under the cam, dead stop.
To date i have heard that 03 pistons were bigger/heavier but haven't seen pics to verify.
Regardless of piston changes, the crank end of the rod doesn't change location.
Whats wrong with the block?
Or crank?
Both NOS, never used.
Pic of block shows oil sensor/cooler line locations so you can see how different an 04/05 block is from the outside.
Other pic shows dent in block from rod contact.
Or crank?
