06 SRT10 conv - Catalytic Converter problems and RR HF cats
diablovox
After ~550 miles of normal highway driving, the car suddenly started sputtering and refused to go over ~3500 rpm in any gear.
The cockpit smells like raw gas, i almost thew up..
I nursed it to a buddy's house i columbus, oh and checked codes etc -
No codes
No misfire
No check engine light
13500 miles on the car
So I took it to a local Dodge/Mopar shop and they say one of the CATs is plugged and quoted me $3200 to replace both, $1200 for 1 CAT, and $850 for the other + labor and gasket etc.
Mopar Ultimate care doesnt cover this, apparently no warranty does.. :mad:
1.
I'm thinking of getting Roe Racing direct fit HF CATs for $750 for the pair and keep the rest of the stock exhaust.
Found this thread - http://forums.viperclub.org/threads/654146-Anyone-Replace-Stock-Cats-with-High-Flow-Cats
AND
2.
this one for the cat delete option but not sure if the dealer would do that - http://forums.viperclub.org/threads/565128-cat-delete-I-found-the-cheapest-way-possible-to-do-this
What do you all think? Am I thinking toward the right solution? **Intend to eventually replace the whole system piece by piece, but not right now**
Thanks!
TalonTSi90
Any car ive seen has flanges on the cats, are the Vipers the same way? Yes, custom, but way cheaper than any option out there.
D
diablovox
Hi flows would work --get ahold of Mark Jorgensen at Woodhouse Viper / Woodhouse Motorsports Division ( [email protected] ) 1-800-889-1893
Thank you! Mark is checking on other options for me to avoid spending $2000 on a set of new OEM ones..
I had ordered the EASTERN direct fit from roeracing.com and the manufacturer will take 2 weeks to make the passenger side.. so this is no longer an option, I'm stuck 8 hrs from home.
I don't want to go with a cat delete, the O2 sims are hard to find on short notice too.. lets see what Mark comes back with..
Does anyone know of any universal ones that might fit? I have the 3" to 2.5" adapters already..
Thanks!
D
diablovox
I just ordered a pair of used OEM from Mark for $650 + shipping, seems like the best option to get me home, and until I get an aftermarket kit.
Thank you Bill for the recommendation, much appreciated!
ViperDEN_Nick
I just pulled my Cats off a couple weeks ago because I went back to straight pipes. I bought them from JonB at Parts Rack. They have less than 500 miles on them, just discoloration on the stainless steel from the heat.
They're the 3" diameter in/out (Honeycomb), one side already has a 2.5" reducer welded on (if you need the 3", just use a Sawzall to cut the smaller pipe off).
PM me
D
diablovox
PM me
Oh man i wish we'd connected just a few days earlier lol! I bought stock pull-offs with 5k miles from Woodhouse and got them installed on the 9th..
Going to keep these until the complete exhaust upgrade..
Thanks!
ViperDEN_Nick
Thanks!
Right on!
I have a Gen II so I don't frequent this section very often and didn't see the threat until it was too late
-Nick
ROIII
