1999+ Vipers Are Creampuffs!
Daffy Duck Viper
Austin, TX. USA.
1992-2002 Dodge Viper Portfolio
MHQC wrote:
Just received it last night. If any of you are contemplating ordering it I think it is great. Lotsa information in it. Some pictures but more articles than anything. And it is mostly tech talk!
However in book they say that there was a cam change in 99?!?! :eek: The specs on this board say that the 2000 cam was were the change went from 66 deg's to 60 deg's overlap, thus being referred to as the "creampuff". Everyone on this board (I think) confirms the change in 2000. Does this mean the article was incorrect? I am actively shopping for a 99rt/10 and one of the reasons is for the rough idle cam. Can anybody chime in here? :confused:
Thanks,
Michael
1999+ Vipers have joined the creampuff category! Talk about stirring the *** *chuckle*
V10 MOJO
Youngstown, Ohio
if im not mistaken (and i usually am as i pay little ttention to anything) the creampuff title was primarily due to the piston change thereby making them "weaker" but im no guru.
C O D Y
Vancouver, WA
Cam Info
Gen I (RT10) Gen II (GTS + RT10 (97-02)) Description 92 93 94 95 96 96 97 98 99 00 01 02 Exhaust Closes (degrees) 43 43 43 43 43 42.5 42.5 42.5 42.5 42.5 42.5 42.5 Intake closes (degrees) 91 91 91 91 91 86.5 86.5 86.5 86.5 86.5 86.5 86.5 Exhaust opens (degrees) 65.5 65.5 65.5 65.5 65.5 82.5 82.5 82.5 82.5 82.5 82.5 82.5 Intake opens (degrees) 21.5 21.5 21.5 21.5 21.5 23.5 23.5 23.5 23.5 23.5 23.5 23.5 Exhaust duration (degrees) 288.5 288.5 288.5 288.5 288.5 305 305 305 305 305 305 305 Intake duration (degrees) 292.5 292.5 292.5 292.5 292.5 297 297 297 297 297 297 297 Exhaust lift (inches) .495 .495 .495 .495 .495 .541 .541 .542 .542 .542 .542 .542 Intake lift (inches) .525 .525 .525 .525 .525 .541 .541 .542 .542 .542 .542 .542 Valve Overlap (degrees) 64.5 64.5 64.5 64.5 64.5 66.0 66.0 66.0 66.0 60.0 60.0 60.0
I see that didn't work, so click here to see the changes....
http://www.viperclub.org/menus/index_ivr_features.htm
As you will see the 96 and 97 have the smallest Exhaust lift & Intake lift out of the gen II's, but has more Valve Overlap.
genXgts
windsor, ontario, canada
Got it Cody,
That 1 thou of less lift is needed for the EXTRA 6 DEGREES of power producing lope to optimize!!
or something like that.....:)
BigCarrot
Dallas, TX
Looks to me like 98-99 are the years to have as far as the cam is concerned. The difference in those and the 96-97 is VERY minor though.
